prentoExplorerJan 17, 2020Norcold fridgeHi all I have a norcold fridge n811,power board 628661,works fine on electric but when you try to light on gas both lights on the control panel flash,you check outside behind the panel you can hear t...Show More
wolfe10ExplorerJan 17, 2020Start by doing a complete "burner area tune-up". No parts and no special tools needed.You will be removing and cleaning the burner tube, cleaning the ignitor/thermocouple and setting its gap.Also, remove the gas jet and soak in alcohol.ONLY if this fails to fix it should you start considering spending $$.
Related ContentNorcold Model 611 Fridge problemNorcold 1210 Not CoolingNorcold RV Fridge Model N640.3Older Norcold fridge issueNorcold gas & electric fridge
