- JerseydevilExplorer
opnspaces wrote:
Does it cool better on gas? What is the model number? I believe you can find the model on a sticker inside the door. If you remove the outside panel can you see yellow powder? With the outside panel open can you carefully touch the chimney area and see if it's getting hot?
N611. Gas no better.
Panel was removed. Made sure no wires were off. Did not see any powder. Tubes and evaporator felt warm. - opnspacesNavigator IIIDoes it cool better on gas? What is the model number? I believe you can find the model on a sticker inside the door. If you remove the outside panel can you see yellow powder? With the outside panel open can you carefully touch the chimney area and see if it's getting hot?
joelc wrote:
? Is it iced up. Does it need defrosting. Where are you and what are the outside temps. What Temperature are you trying to keep it at. I have my Norcold on No. 6.
A muffin fan will work wonders if placed blowing over the evaporator coils outside.
0lder unit 2006. Have stat in middle. Has power, no ice up,light is green,in NJ, about 80 out.
Odd, and freezer has layer of ice at bottom. - MfanExplorerIt might be an easy fix. Is it on? Unplug the thermistor. That will call for max cold. If it gets cold, there is your problem.
- joelcNomad? Is it iced up. Does it need defrosting. Where are you and what are the outside temps. What Temperature are you trying to keep it at. I have my Norcold on No. 6.
38,738 PostsLatest Activity: Jul 26, 2025
