If you open the outside access panel to the reefer, you should be able to see the water line going to a valve and then going to a solenoid and then from the solenoid to the reefer. These solenoids frequently fail and are inexpensive and easy to replace. First thing would be to see if there is any water going to the solenoid - that would eliminate filter and other supply problems.
