bgosden wrote:
Ah! snip/
We will try the thermistor, and then attempt to do the test you mentioned to test the cooling unit. I am not certain on how to wire it to outside 120v power, but my husband might know how to do this to test that.
Thank you so much for your help.
Your fridge is plugged in to a 120VAC receptacle behind it like your household fridge. Access thru outside panel. Simply plug it into an extension cord. 12ga. preferred. Or you could use adapters and plug the entire coach in, but I'd isolate the fridge for your check....Dennis
