tohare wrote:
Norcold frig model 1211m, just stopped working. No power, no anything. Checked the circuit breaker, and outside power. It is in a 2008 destination. Any ideas?
A little help here. What are you seeing on the front panel of your refrigerator?
Has your 12 volt to the house been inadvertently shut off. Your control board for your Norcold requires 12 volts to operate. Your 1211 only require 120 volts AC when it is in electric mode... But 12 volts is required for both AC and propane...
Other than the 12 volt issue the other gremlin is whether or not you have the recall installed and it has tripped...
You will need to see if you have a red light on you control board. which would indicate that the over temp alarm (the recall) has tripped.
It will be helpful if you let us know what your problem turns out to be.
JohnnyT
