tohare's avatar
tohare
norcold not working
Norcold frig model 1211m, just stopped working. No power, no anything. Checked the circuit breaker, and outside power. It is in a 2008 destination. Any ideas?
  • Does it have the recall box?
    Is the Red LED Light ON?
    IF a high temp excursion is sensed the recall box shuts off all power.
    Question then is..was it a 'real' high temp trip OR a faulty recall box.
    Assuming your 12V supply is operational and working correctly???then it sounds to me like the recall temp sensor kicked in.Pull the rear cover and see if the red lite is lite up on the Black sensor recall box. if it is thats the problem in that either the recall failed and needs resetting or your cooling unit has failed,overheated and shut off which requires new cooling unit
