doxiemom11
Jul 02, 2017Explorer II
We have also solved problems that were wires that vibrated loose or were corroded. Once a good connection was re-established things worked fine. The other thing you can do is disconnect both the AC/DC plugs from the outside, let it sit a few minutes and then reconnect the DC then AC. Sometimes that will reset the control board.
38,777 PostsLatest Activity: May 24, 2026
