- FIRE_UPExplorer
Bruce Brown wrote:
On the welds, be sure to cut them with a cutoff wheel or grind them off, don't take a torch to them.
I see you're in Syracuse. Feel free to PM me if you need any help removing it. I'm in Syracuse on a somewhat regular basis.
Well,
That's fine IF, you have the clearance at all angles to manipulate a cut-off wheel and motor. There's nothing wrong with using a torch, IF you know what you're doing. Of course the cut would be cleaner with a cut-off wheel.
This SPECIFICALLY why I advise to install any M/C lift by BOLTING it on. That way, there's no need for any CUTTING when it comes time to remove it. And, it's just as strong. Oh well, I'm sure the OP will deal with it.
Scott - Bruce_BrownModeratorOn the welds, be sure to cut them with a cutoff wheel or grind them off, don't take a torch to them.
I see you're in Syracuse. Feel free to PM me if you need any help removing it. I'm in Syracuse on a somewhat regular basis. - JoeHExplorer IIIKeep the Blue Ox tow bar-- you will probably eventually want to pull a car with you.
- wa8yxmExplorer IIIKeep it.. Buy a Bike to lift with it.
- IvylogExplorer III:WGood job of selling it on a site that does not allow selling items.:W
- luberhillExplorer
Nutinelse2do wrote:
Yes, the triple receiver is welded to the coach.
The buyer of the lift would have to purchase one separately.
If it is an overbilt, find out from the previous owner when he purchased it.
If it is an older design, it had some problems. That design got sold to Blue Ox I believe.
Hopefully it’s fairly new, within the last couple years, which is a much better design.
Overbilt’s are not hydraulic. It is cable driven. They hold 800 lbs. Different racks are required to carry a quad or golf cart. Oh, btw, waaay too much weight for the back of a 25 foot Class A.
Who has a 25 ft A ?? They only weigh 250 pounds - Dale_TravelingExplorer II
I think you need a few more 'AAAAAAAAAAAAAAA' is waaay.
Don't worry about the needing a replacement receiver. Not hard to replace or to have one made. The hardest part of selling it is if it needs to be shipped. Size and weight are the issue. - Nutinelse2doExplorerYes, the triple receiver is welded to the coach.
Overbilt’s are not hydraulic. It is cable driven. They hold 800 lbs. Different racks are required to carry a quad or golf cart. Oh, btw, waaay too much weight for the back of a 25 foot Class A. - luberhillExplorerhttp://www.overbiltlifts.com/
I THINK its this one but ill let you know, I know he said you can tow a car also there is like 3 receivers...one part of the bracket is welded right to the frame so you would probably have to buy another.
Ill call the manufacturer tomorrow and ask him
I can tell you this thing is HEAVY duty, he had his big road bike on it but only used it a few times since installed - camperdaveExplorerThose things cost $$$! Figure out how much it cost new and sell it on Craigslist for 1/2 that amount. I wouldn't do other online or eBay because there is no way n you are shipping that thing. Local sale only.
38,766 PostsLatest Activity: Jan 10, 2026
