brickExplorerMay 22, 2015nwh jacksI have the straight jacks with joy stick. When I try to use the jacks the proper lights are ok on the control panel but when I try to raise the jacks I get only a click from up front. The pump does n...Show More
brickExplorerMay 25, 2015Thanks for the help with my problem. Following suggestions I found problem was ground to the switch. Everything ok thanks. Brick
Related ContentAtwood Electric Jacks - Replacement ElectronicsJackJack Failure DisasterLeveling Scissor JacksJacking For Tire Change
