Baja_Man's avatar
Baja_Man
OEM Service manuals for 2005 Ford E450 Chassis
Hello all--
I just purchased and will be picking up a new to me 2005 Class C on a Ford E450 chassis. Would like to service as much as I can myself and learn more about my new toy!
I would like to know where complete factory service manuals can be obtained. I would like the complete set that includes:
Chassis, Electrical, Engine, Transmission, Brakes, HVAC, Diagnostic, etc.
Ford used to print thick books for each section of vehicle as described above. They were VERY complete and thorough books and were used by Ford authorized factory service dealerships/centers.
Thanks!
  • "Ford used to print thick books for each section of vehicle as described above. They were VERY complete and thorough books and were used by Ford authorized factory service dealerships/centers".
    Helm used to print for about all OEM'shttp://www.helminc.com/helm/welcome_select_oem.asp?Style=helm
    Couple things first...Lots of money for the real manuals, some items won't matter if you have the books or not as testing equipment on some items is even more $$$. El cheapo books from Auto part store should help and tons of info on line at different forums. As far as service items and when, try and insert VIN number. https://owner.ford.com/tools/account/maintenance/maintenance-schedule.html#/
    When I got our 1 ton class C I bought a cheap scanner and fuel pressure gauge and couple others things and spent about $150.00
    For your year model (in my opinion) learn about changing the fuel filter, in tank fuel pumps, fuel pressure testing and how to trouble shoot COP's(Coil Over Plug) where and how to clean MAF and how to use o/d correctly.
    Use only OEM oil filter (built in silicone valve) to prevent oil leaking back down after shutting off motor. Most part houses will have filter you need.
    Do the maint and you should be many get 250,000-500,000 miles on them. Motor will out last rv chassis I bet.
  • Helm is the publisher and retail outlet for Ford service manuals. helminc.com for information. Ford parts orders from Helm, I don't know if they do a markup. There are businesses offering to sell "official" manuals more cheaply but I don't know what they are selling.
    There is a difference between service manuals and workshop manuals, the latter being more detailed and much more expensive, obtained usually by subscription.
    There may be online sources for free downloads of factory service manuals or the workshop manuals. Try workshop-manuals.com, fordservicemanuals.org, or www.repairmanuals.com.
    My levels of DIY have found Chilton or Haynes manuals adequate, but the closest you'll get to E-450 will be the Econoline or E-Series collectively over a rather broad range of model years.
