Edd505
Dec 10, 2017Explorer
You spend 100K plus for a DP or 70K for a diesel truck and worry about a couple hundred for oil? There is no maintenance you will do that will make it last longer than clean oil & filters. Two diesel P/U's changed once a year 1 210K the other 163K never need apart. Class 8 750K changed MONTHLY @10-12K per, replaced 1 injector. An oil change & filter change a year is peanuts.
38,769 PostsLatest Activity: Apr 04, 2026
