shannon62's avatar
shannon62
oil change
Hello, i have a class a motor home & would like to change my own oil & filter, does anybody have any suggestions on where i can do this, i am fulltime & the campground i am staying does not allow this. Thanks for the help.
  • I would probably hire a mobile mechanic or just top it off and keep going.
  • Find an auto parts store with a large parking lot and ask if they mind. I've seen plenty of people doing minor work in parking lots.
    I'm assuming you don't need a lift or anything extravagant to change the oil. If you have one of the pumps that will draw oil out from the dipstick and the oil filter is easy to reach, just make sure not to make a mess and likely no one will have an issue.
    Most auto parts stores will accept used oil for free, so disposal isn't a big concern.
  • I know you said you wanted to DIY but for the hassle of finding a place, the task itself, wrench, drain pan, buying the oil and filter and disposal of the old oil I would just take to a truck center or RV dealer to have it done. Anymore you don't really save a lot of money doing it yourself and it's certainly less hassle and mess. There is a reason CG's don't want people changing oil and primarily it's the risk of a spill and the disposal of the old oil. I think you'll find the same concern anywhere you would try and change it that wasn't personal property.
  • With all the hazardous waste laws, regulations, rules and fines, I don't think you will find anyone (just like your campground) that is going to let you change your oil on their property.
