Hello Everyone… I have a 2003 Ford F-53 RV Two months ago I did an oil change, the recommended amount was 6 quarts, but most forums recommend adding 5 quarts fits then check the level and add as...
Have you been running the engine. If not then it got spilled when you put the oil in if you put it in at the engine. As stated engine oil does not go thru Compressor. Is the oil drip clear or the color of engine oil.
