Hello Everyone… I have a 2003 Ford F-53 RV Two months ago I did an oil change, the recommended amount was 6 quarts, but most forums recommend adding 5 quarts fits then check the level and add as...
You should, when changing both oil and filter (When you change one do the other) run the engine for at least one minute or long enough to get it warm and then re-check the level right away.. you may need to adjust oil depending on the filter you installed... many engines have more than one filter that fits.
