xctraveler wrote:
Just looked at the chart myself. Unless you are running over the G rating weight limit 5355(G) Single, 5070(G) Dual, you can work with the chart numbers given. They appear to be the same at lower weights. The high weight is for G rated tires and the lower weights are for F and G and presumably H.
The H will give you greater sidewall strength and a slightly rougher ride than the G, but they will not increase the weight you can carry on each axle beyond the rating on your sticker.
Paul, believe you were looking at the 265/70. Mine is a 245/70. I'm not upset with the H rating just don't know why I can not find any reference to it on Goodyear charts for my size tire. In fact, I'm glad to have that higher rating even knowing the ride might be a bit harsher. A G rating would have been 'adequate' for my weight carried.
