goufgators's avatar
goufgators
OK...now I'm confused !
Just had new Goodyear 245/70R19.5 Load Range H installed on my MH. On looking at the on-line Goodyear Load/Inflation chart it does not show a Load Range H for 19.5 tires. 19.5 tires according to the chart only go through Load Range G. According to the chart, Load Range H exists only on 22.5 tires. But, my new tires are 19.5 and clearly Load Range H.
I know I can go back to the Goodyear dealer but was wondering if any of you have experience with this or otherwise have an explanation. Are Goodyear charts simply not up-to-date?
Thanks/ Larry
  • The list you saw is probley old and never removed. This happens alot on the internet. PSI should be on the tire side wall amid a whole bunch of other numbers. Once you find it write it on the garage wall by the compressor. Best of luck
