jplante4 wrote:
Ok that makes sense. I did a search on the subject and saw that the difference in fuel consumption is about .2 gph. The DW isn't big on boondocking, so I guess I'm good. I wanted to make sure there wasn't a boogey man sitting under the bed. :)
Where did you get your figures???? 1.2 gallons lp at full load
LP on a 6500
No load
Half load
Full load
60 Hz
0.5 Gal/h (2.2 lb/h) 1.0 kg/h
0.8 Gal/h (3.5 lb/h) 1.8 kg/h
1.2 Gal/h (5.3 lb/h) 2.4 kg/h
6000 Diesel .4 gallons 1/2 load .7 gallons full load
You MUST take into account that LP tanks rarely have more than 25 gallons liquid capacity which restricts running the LP genset no more than 20 hours. DIESEL Tanks are in the 100 to 150 gallon range and that translates into up to 4 to 7 days continuous running and it is a LOT easier to refill the Diesel tank than the LP tank. LP Gensets drop the value of a motorhome at least 10k. Very few Diesel Class A motorhomes come with LP gensets in the past 15 years. Before that Diesel gensets were a LOT more expensive and to get the price down the OEM's offered the LP as standard with the Diesel as a 3k to 5k option. As someone who has been in the sale and service of Motorhomes for 35 years(I am a Technician), we had multiple problems with the LP gensets 20 to 15 years ago and after all those problems even at brand new delivery, the Dealer Owner decided to NEVER have a Class A motorhome with a LP genset. WE ordered all our Motorhomes with Diesel Gensets starting in 2000. From what I have seen, I would NEVER have a LP Genset on a Class A Diesel. LP Gensets gave a hi failure rate of the LP Regulator. They either GUM up or they leak. Very expensive to fix. On our new Class B units with LP Gensets we have continual problems with them. If available we also option the Diesel Genset on Class B units. Doug
