rockhillmanor wrote:
On the same subject. I put Stabil in my tank before I parked it. Due to health issues unfortunately it has sat for a period of time.
Will the Stabil 'already in the tank' be ok to start it up? Or should I add fresh gas to the tank BEFORE I start it up? V-10
As per Stabil, with the proper amt you should be good up to 24 months. ( The myth of adding more Stabil does NOT prolong things longer than 24 months).
When storing a partially full gas tank, it can allow moisture to gather in the tank and lines more so than a full tank. Ethanol gasoline adds to that reaction more than non ethanol gasoline.
Gasoline will oxidize and deteriorate in storage. Old gasoline will cause hard starting, and it leaves gum deposits that can clog the small passages in the fuel system. If the gasoline in your vehicle deteriorates during storage, you may need to have the carburetor and other fuel system components serviced or eventually replaced.
It will depend on how long the gas has been sitting. See how it starts up, if it runs rough, stop, drain and refill it with fresh gas and a bottle of Seafoam to clean things out. I would drive to get the rpm's up to allow the Seafoam to work. You can add more Seafoam to the tank as the formula suggests, it would not hurt the system. I have done a double dose many times on a gunked up generator engine. I let the rpm's crank up under a load .
I hope you are feeling better,
Bob
