rgatijnet1
Aug 20, 2017Explorer III
Always tough to figure out electrical without being there but I will give it a chance........Use your voltmeter to find out what part of the electrical plugs get power when they are working correctly on your '64 Impala. Draw yourself a little diagram if you have to.
The go to your motor home and with the headlights on low and high beams, see what wires you have to move, or jumper, to get the same voltages on the same pins as with the car.
Make sure that you know what pins are grounds.
