- 1968mooneyExplorer
steppinstone wrote:
Well I guess my 1988 sunvista high rise is the only one on the plant so it must be worth millions . Just kidding I had purchased this unit the same time late last year and been working on the coach making it more modern fluff and buffing it. In the rear there are 2 bench seats which was an opption at the time and a fold down table that make a bed (not very comfortable) I would like to remove and put a king size bed. I was wondering if anyone has one like this ? The only reason I ask is because on the driver side the generator and fuse panel is located under that bench.So if I remove the bench how would I cover them and still be able to walk around the bed. I have done the bathroom over ,new shower ,shower door,granite counter, wife is in the process of picking out tile for the back splash,.I have also put new 3/4 tung a grove red oak flooring and carpet.out side window awnings and leveling system, satellite system. After I figure out the rear bed room I will be put in kitchen counter,w/granite and back splash tile there also.
Just a reminder. Go have it weighed. With all the improvements you have made you are probably many 100's of lbs. overweight. - steppinstoneExplorerWell I guess my 1988 sunvista high rise is the only one on the plant so it must be worth millions . Just kidding I had purchased this unit the same time late last year and been working on the coach making it more modern fluff and buffing it. In the rear there are 2 bench seats which was an opption at the time and a fold down table that make a bed (not very comfortable) I would like to remove and put a king size bed. I was wondering if anyone has one like this ? The only reason I ask is because on the driver side the generator and fuse panel is located under that bench.So if I remove the bench how would I cover them and still be able to walk around the bed. I have done the bathroom over ,new shower ,shower door,granite counter, wife is in the process of picking out tile for the back splash,.I have also put new 3/4 tung a grove red oak flooring and carpet.out side window awnings and leveling system, satellite system. After I figure out the rear bed room I will be put in kitchen counter,w/granite and back splash tile there also.
38,763 PostsLatest Activity: Dec 05, 2025
