mlts22
Aug 10, 2015Explorer II
SeaFoam is definitely cheaper than a new carb. Definitely will try that right. I've also read about people pushing Seafoam directly into the intake of the genset as well.
Only downside -- if you SeaFoam the generator by putting it in the fuel tank, you will be SeaFoaming your engine as well, so I'd probably consider an oil change after you run that stuff through the lines.
