Belgique wrote:
At the Genset it drops to 8V +/- when starter pressed. At the house battery bank (2 ea 12V) it is around 11V when starter pressed.
AZA: connections all check and thanks for that suggestion.
The starter seems to want to try but not enough juice.
Well all of the connections aren't good. The voltage at the gen should be within a half a volt or so of what it is at the battery.
Did you check the negative connections.....grounds ??
You have entirely too much voltage loss from the batteries to the generator.....indicating a bad connection somewhere. Outside chance that the solenoid is bad but not likely I think.
Note:
If you are not plugged in.....and the truck isn't running.....it should be trying to start from the house batteries only. plugging in adds the converter/charger. Running the truck should bridge in that battery too.
