handy2sum
Aug 09, 2018Explorer
per our manual, code 32 is low cranking speed fault and
if fuse 32 is ok, then probably have bad battery connections or weak batteries.
So... check for corroded or loose connections / tighten all battery connections. Voltage at post may be fine but not enough current getting through to motor due to high resistance somewhere in the circuit.
