iamalienru wrote:
I saw the u tube viedo. i did everthing they said the only thing i haven't tried is wait days for the to escape. I do work for living so getting back to will occur within a day or two. checking for viedo's and online is the first thing i do. At first i did fill through the overflow tank but corrected that and filled through the fill cap under the panel. Now i am still having the same problem. time may be the answer to this. If the engine had a bleed port on the block I figured this would allow the air to escape quickly..I will update this weekend as to my progress. could only be temp sensor or thermostat sticking
Well Sir,
It will help if you say if you've got any codes displayed on your start switch. No need for guessing if one is displayed.
scott
