RV_Hero's avatar
RV_Hero
Onan generator Carb cleaning, no need to replace carb.
putting a T in the line feeding the carb, then I can hook a hose to it with carburetor cleaner , coming from a bottle held higher then the generator. This way I can put a concentration of carb cleaner directly into the bowl...run for a minute shut off and let it sit for 30 minutes so it removes all the gum and gunk from inside the carb.bowl, then restart,,, when done reattach gas line...what do you think...this would saved over $700 cost to replace carb.....This cure would save everyone with these generators a lot of money.....Call me RV Hero......one note I used Sta-bil treatment in my gasoline. research that fuel is pumping has shown me that it is in the carb. a little cleaner in the gas line makes it start and run for a few minutes. needs a bigger dose.
Day 2,,, I did the concentration trick filling the carb and running it on B12 and seafoam, let it soak about 20 minutes ran it and did this 5 times,,,then filled it again let carb take only the mixture...out of a plastic peanut butter jar... then let it soak for 5 hours....then started again,,reattached gas line and put everything back to normal...it runs but rough idle...I need to choke it to start it...now I am going with the gas filter and fuel pump switch...maybe not enough gas..when I checked the gas flow before I started it pumped but small stream.....I do believe the inside of the carb is clean...from all the carb cleaners...does anyone know how much gas should pump? Thanks
  • I thought that's what most people do when using Seafoam to clean the generator carb. It seems like common sense.
    Or, maybe it's just as easy to remove the fuel line and attach the cleaner line.
    Maybe I'm missing something?
  • It likely won't restart, any mung loosened will clog the jets. There is really no need to replace a carb that isn't severely worn, damaged or corroded and no amount of cleaning will cure that. Careful disassembly and cleaning should solve most problems, just hope you don't need a kit as Onan is very proud of those too.
