wildmanbaker
Aug 05, 2015Explorer
Not the wiring plans that Fleetwood will send you, but the build/repair plans that are used to build the MH, and RV techs use for repair. Before just replacing the batteries, use a hygrometer to test the cells. Use a manual charger overnight, and test again after an hour of rest. If the hygrometer and a voltage test are good, a load test can be performed. If the batteries are good or replaced, you really need to find out what the hidden loads are, to prevent draining the batteries.
38,777 PostsLatest Activity: May 24, 2026
