JumboJet's avatar
JumboJet
Onan Generator Starter Battery - Which one?
Specifications:
Motorhome - 2003 Fleetwood Expedition 34W - Cummins 5.9 ISB
Generator - Onan/Cummins Quiet Diesel 7500
Which battery group is best to use to start the generator? Engine batteries? House batteries?
Issue #1: House batteries are used for 2000 Watt Inverter. Generator will not start when house batteries are at 10 volt cutoff to the inverter.
Issue #2: House batteries are being replaced and I wonder if it would not be best to move the generator start cables to the engine batteries, OR install a separate battery for starting the Onan generator and provide a charging wire from the engine alternator?
When the generator is powering the Xantrex Inverter/Charger, the house batteries would be re-charging.
  • I have to ask.....why do you want to rewire what Fleetwood designed. You give a lot of reasons why there could be a failure, but none of them will come to fruition if you maintain your batteries, both house and chassis, properly.
    About the only thing a coach of your era really needs is a battery maintainer that charges your chassis batteries while plugged in. There are three companies that make them, Xantrex, TRIK-L-START and Magnum.
  • I got stranded once with dead chassis and coach batteries ... after that I moved everything that was attached to the chassis battery to the coach battery. I also got in the habit of starting the RV before I tried to start the generator - that put all the batteries on-line and generator seemed to start quicker and didn't tax batteries as much.
  • tropical36?
    Actually, don't you have that reversed? Doesn't the "battery boost" switch you refer to allow the "house batteries" to assist the engine starting battery when it's too weak to start the engine?
    Maybe I've had the wrong idea all these years.
  • JumboJet wrote:
    Specifications:
    I believe the house batteries are preferred and if they go dead your battery boost sw. can be used to start the genset. Also starting the main engine should charge the house batteries pretty quickly.
