Berner2
Mar 02, 2015Explorer
I have a 2004 coach with a 6.5kw propane Onan. A couple years ago I had issues with it starting and running, it smelled like it was running rich when it ran. I had it in the shop and they cleaned up the carb which was gummed up and a replaced a hose or did a couple of other things. About $1200 total! When I got it back I started doing little research and found that if the propane is fed from the liquid side, which mine was, it tends to gum things up. I swapped mine over to the vapor side with the appliances and haven't had anymore trouble. Might be worth a try!!
FWIW, I have no knowledge of any recall.
38,763 PostsLatest Activity: Dec 05, 2025
