PursuitInsight wrote:
sorry about this. i related my experience, first hand and this was 3 weeks ago that i replaced the oil. i only wanted to help and have no explanation but the result was that 1 year of 2x4 and a wood block (still in the motorhome) action is no longer required.
i experienced it, you know better
Yves
edit: brake fluid is contaminated by rubber deterioring and not moisture
it becomes black with hose particules
Brake fluid breaks down from heat and absorbs moisture which results in lower boiling points in the brake fluid which leads to brake fade failure under hard braking and Class Gassers all have hot brakes at one time or another
