Clay_L
Feb 07, 2016Explorer
If this is a Class A ,Winnebago glues the windshield to the steel frame. The rubber molding is not for sealing and is strictly cosmetic.
Winnebago has a known problem with the steel frame rusting which pushes the windshield out slightly causing leaks and cracking of the glass.
I had to have both sides of mine replaced. I had Winnebago do it and they removed the rust and applied a rust converter/sealant to the frame.
If that is your issue you need to get the rust taken care of before the frame is damaged too much. If bad enough that is an expensive thing to repair.
38,782 PostsLatest Activity: Sep 10, 2026
