DSDP_Don
Feb 07, 2016Explorer
It may not be the windshield. Often, when the windshield is leaking, it runs down the inside of the glass and will be wet against the windshield, unless yours is slanted toward dash where you're seeing water.
What often causes this leak are the running lights. They loose their seal and the water comes in the front cap and drips down on the cabinetry and curtains.
It will be a pain, but you need to identify what is leaking. Often you can run a piece of duct tape or even a wide roll of blue tape across the top of the windshield and see if that stops the issue. If it does, you need the windshield repaired, if not, you need to look elsewhere.
38,782 PostsLatest Activity: Sep 10, 2026
