AikenRacer's avatar
AikenRacer
Open Ground Electrical Issue
Several years ago, I had a 30 amp outlet installed at my house. Prior to going on a trip, I bring the MH to the house, plug it in so I'll have power to run the fridge and sometimes one AC while we pack. All total far less than 30 amps. Done this many times. I use an inline Progressive EMS. The MH has been at the house for two days now. For this trip, only the fridge runs, no heat or ac. Today, I hear a switching sound from the inverter and it turned out to be the EMS blocking the power to the MH. Error code says open ground. I use 2 30 amp drop cords and an adapter to go from the outlet on the home to the EMS. So I start looking and see that one of the male hot legs of the 30 to 50 amp adapter is melted along where it plugged into the female end of the cord. What would cause this?? Please answer in layman's terms as I am no electrician by any means. Thanks!!
  • Can you find another 30 amp to plug into to?...as it could be cord/ground plug on cord or the 30 amp itself...Get a tester and use a 15 amp converter plug...is ground showing good?...if so, it is the cord, if ground is showing open it is the plug.
