rgatijnet1 wrote:
dodge guy wrote:
rgatijnet1 wrote:
I adjusted mine by using a pointer I taped to the top of the steering wheel. I drove down a decent highway and marked on the dash where the pointer on the steering wheel lined up with each other.
Then I went back to my driveway and used the levelers to raise the front wheels off of the ground. With the wheels off of the ground I adjusted the Tru-Center so that the steering wheel pointer aligned with the mark that I put on the dash. That was all it took to have it adjusted so that I did not have to fight against it when driving down the highway. With the Tru-Center it took much less input from me to stay in my lane. .
It’s not meant to be used like that. It’s meant to be set in various conditions.
I sometimes reset it many times throughout the day.
Going on 60,000 miles with mine and I don't plan on changing the way I use it. Perhaps you have to adjust yours so much because you never set it up right when you first installed it.
Its not a "once and done" setting. its designed for different driving conditions. wind, road crown, etc. and yes its installed correctly!
