Dale_Traveling
Jun 30, 2020Explorer II
rhudson1111 wrote:
,,, The reason I talked about a gas generator previously on a larger rig was, that someone mentioned that if I'm going to live aboard or spend a lot of time on it, that a gas generator would be needed for ongoing power of all appliances for multiple days. I'm learning as I go. If the majority agree not needed, I'm happy not to spend money on it :) Thanks!
The onboard generator should be size to power ALL appliances install when the coach rolled off the assembly line. The assembly line part is important as an owner installed second A/C might be too much for the generator with the original A/C also running. You should have the owner bring the generator on line and run the coach roof A/C and anything else you can easily turn on to try and load the generator as much as possible but staying within its designed limits.
As mentioned it would be unusual for a class A not to have a generator plus your description of the coach included "refurbished generator".
38,782 PostsLatest Activity: Sep 10, 2026
