- Tom_BarbExplorer II
Nutinelse2do wrote:
Tom/Barb wrote:
Nutinelse2do wrote:
we knew that,, we are looking for our friends.
I would say your Newmar is much better quality.
Ok, now that make sense. I would think going from Newmar to Four Winds would be nutso. Just sayin. And, I was hoping you were selling your coach so we could buy it from you :-)
We could never charge anyone, what the Mountain Aire is worth to us. :) We have repaired every thing so it works, up graded a lot of stuff. but it is still 17 years old. but only has 40k miles.
They are a couch built to last a lifetime. - Nutinelse2doExplorer
Ok, now that make sense. I would think going from Newmar to Four Winds would be nutso. Just sayin. And, I was hoping you were selling your coach so we could buy it from you :-) - Tom_BarbExplorer II
I would say your Newmar is much better quality. - Nutinelse2doExplorerI would say your Newmar is much better quality.
- BobGedExplorerThere is a Mandalay Yahoo Group that you might want to check out. I seem to recall there was an issue with some Mandalays, not sure of which years, having to do with the windshields popping out that was required to be repaired at the factory.
I believe it was called the "halo modification", which required the installation of a metal support brace around the windshield opening of the coach. The procedure involves removing the front end of the coach, and welding a brace in place. - John_WayneExplorer IIYou did see the damage on the bin door on the drivers side
- ScottGNomadWow, if I were in the market I would take a serious look at that coach.
(I'll even be on Whidbey this weekend bwa, ha, ha!!) - gboppExplorer
Kayteg1 wrote:
It is located in beautiful area, I would make mini-vacations out of inspection.
It would be a very mini-vacation. The OP probably lives less than 15 miles from the seller. :) - IvylogExplorer IIIIt's close enough and I do not see the engine rusted problem mentioned above. Yes, The hydraulic oil tank has the paint coming off of it but nothing else. The propane tank area appears to be rust free. At that price I would want new tires and batteries on it.
- Kayteg1Explorer IILooks good on the top, but corrosion in engine compartment indicate driving over salty roads, or exposed to salty breeze.
Don't hesitate to spend good money on PPI
