rk911
Feb 23, 2015Explorer
dfreiberger wrote:
Hope I can answer all your questions with my facts/opinions. I own the Winnebago Adventurer 38Q which is the same rig as what you are looking at.
We love the floor plan. I really like how all the electronics is wired through the matrix which makes controlling all the equipment easy. I installed the Direct TV Satellite Dish and it works great.
We have the solar panel option which is a great option. It will trickle charge your coach batteries while your rig is just sitting, such as storage. The Solar Panel system is wired direct to the coach batteries so this means you can turn off your coach power and continue to charge. It also keeps you from having to remove the batteries while storing. Mine has been stored in the cold since December and the batteries are holding 12.6v continuous.
I am 5ft 10 and weigh 220. The shower works fine for me. I like the longer shower which allows me to pick up the soap. Ha. Not a problem we see so far.
We also have the same radio with the Nav. The nav. is supposed to update automatically through satellite, or so I was told. I also remember reading in the owners manual. The only issue I have is that we believe in the passenger being the navigator. This means The Rand McNally is mounted more towards the passenger who can give the directions to the driver. My wife drives the rig also, so basically, the driver drives and the passenger navigates. The problem with the installed optional system is the way it is positioned in the dashboard. It is angled towards the driver so the passenger cannot see or control the unit without getting out of the passenger seat.
The residential fridge is great. Turn on the inverter and the fridge will power off the coach batteries which are continuously charging while going down the road. And while parked, say at a rest stop, they charge through the solar panel, if you install that option.
We love how the sofa makes into a bed and how the seats recline while relaxing.
We do not do the oven anymore. They cook terribly and waste space. We went to the convection/microwave on our last two RVs and love it much better, also allowing for more pot/pan storage.
The driver's door is a nice feature but I keep forgetting it is there. I did not have it in my last motorhome. I think the door causes more road noise and it rattles until the tires warm up and round out making the ride smoother. I hardly notice the noise anymore. I think I would rather not have the door. It creates some blind spots due to the door and window frames being bigger.
Hope this helps.
it does and thanks. yes, we're opting for the solar charger. our current suncruiser has the same option. re: the sofa and chair...we've found the 'euro' style couch and chair to be very uncomfortable. our dealer has been made aware of that and assures us that there are other options from the factory for the couch. we've located a std. residential recliner that we think will fit in the same space.
I'm pretty sure that the driver's door is std on the 2015 model. we have a DD on our current suncruiser and while I don't use it as my primary entry/exit while on the road it has come in handy while parked.
other than the nav system being out of the view of the passenger how is it as a GPS? accurate? how about the AM radio...can it receive as well as a standard automotive radio? for example, in my Jeep I can pull in WGN in Chicago almost as far south as Effingham, about 2/3 of the way to St. Louis. in the suncruiser I can barely pull that station in for 50-miles.
thanks again.
38,782 PostsLatest Activity: Sep 10, 2026
