Mich F wrote:
Chances are that connection near your water and electrical connections is/was for a park cable connection. What's on your ceiling under where the old crank up antenna was ? Most likely the wall plate with the plug and switch was the amplifier/booster for the roof antenna. Any sign of the cable outside on the roof, where the antenna was ?
No, there's no sign of anything up there. I plan to pull the plate down tomorrow and see what is run to it and I was hoping that the switch was a booster. Is the outside cable connection normally run to a splitter so you can use either the antenna or outside connection?
