rgatijnet1
Jul 19, 2018Explorer III
One of the members on another forum blew TWO 8.1L engines with their coach. There was NOTHING wrong with the rebuilt engines and the ultimate culprit turned out to be a bad MAF that was reused when each engine was changed. Most engine suppliers only supply a long block and the mechanics take the "accessories" off of the old engine. If the MECHANIC that changed your engine used the old accessories, without ever checking them, and the MAF turns out to be defective, Jasper may deny any claim that you have. If the engine blew because it was run too lean, that is not Jasper's fault.
Best of luck with the outcome and I hope someone will step up to help.
