bsinmich
Jul 21, 2013Explorer
It gets cold here in Holland, MI. I store my MH in a barn (unheated)with concrete floor but not hooked to any charger. I have a solar panel on the roof but in the dark barn that does nothing. I do have the gas tank full, Sta-Bil added to the tank and run the generator prior to parking for the winter. In the spring I start it up like normal. For winterizing I drain the water heater, hook the air compressor to the water inlet and blowout all of the lines until they finally quit spitting. This way I avoid having to play with the bypass valves on the water heater and by adding water I am set to go in the spring. I use about 1/2 gal. of pink stuff in the traps in the MH. It works every year.
38,769 PostsLatest Activity: Mar 29, 2026
