iamalienru wrote:
i changed the radiator because i picked up a bolt on the freeway that caused a small leak in it. i have changed the radiator cap. fan speed looks to be fine rotating at high revolution. i did notice that the site glass to the fluid tank had a slow leak from its O ring i replaced it now i just have to get warmed up and pull a grade with it because it won't get over 185 degrees just running it. when it heated up i was pulling with my boat so i may have to recreate the situation any grade would send the temp to unsafe heat level. As soon as i got off the grade temp goes right back down to 190 thank you for all of the information you all provided
all Diesel MH,s will run considerable hotter when loaded pulling a steep hill.Your,s getting to the boiling point indicates you may have a combustion leak(maybe) or your fan is not engaging when it should and not full force.There is a fan control switch right at the fan hydraulic drive unit.DISCONECT the wire harness.This will default your fan to high speed.Try it like that and see how the temp goes
believe me its certainly not as simple as a rad cap or anything silly like that
