BigGuy82's avatar
BigGuy82
Overbilt Motorcycle Lift Experiences
I hope this is the right forum for this. I am taking delivery on a 2016 Itasca Solei 38R pusher in a few weeks and want to put an Overbuilt motorcycle carrier on it rather than towing a trailer. The lift plus my Gold Wing tags in a 1,300 lbs. Overbuilt says it's no problem for the frame to handle and the dealer says the unit can handle it also. BUT, here's what I'm looking for.
What happens to the control characteristics of the coach? The math doesn't change ... the rear wheels are a fulcrum and the more weight you put behind them, the lighter the front end becomes. The question is how much? Does this negatively impact control or are the effects negligible? I've checked a variety of forums and what I am looking for but can't seem to find is someone who owned a motorhome, drove it for a while and then put one of these things on. Lots of opinions and generalities but no hard facts (at least that i could find).
Long story, simple question: did the installation of this unit make your diesel pusher noticeably "lighter" in the front end?
Thanks!
  • Ivylog's avatar
    Ivylog
    Explorer III
    It,s not the 600 lbs you are going to take off the front, it's the 1900 lbs you are going to put on the rear axle that's the problem. What is the hitch rated for and how much CCC do you have?
  • Peralko - thanks. That's the math and while I can figure the change in weight distribution, I want to hear about the actual hands on effect from someone who has driven their coach before and after. I other words, does it "feel" noticeably lighter?
    Thanks!
  • Absolutely! To find out how much weight comes off the front end, measure the distance from the rear axle to the estimated center of gravity of the lift/motorcycle. Divide the combined weight of the lift/motrcycle by this distance and multiply by the wheelbase, and you will have the weight reduction on the front axle.
