- Tom_BarbExplorer
1SG wrote:
I understand the appeal/need for these rigs as I see a lot of them at the dragstrip.
If you need the towing capacity of a class 8 truck you can't go wrong with one of these. There are plenty of manufactures and used units on the market. You might check www.racejunk.com for used units, but that is only my wallets opinion.
Go for it.
Paul
My question was, Why do you need that capacity for full timing?
His load as discussed was well with in the capacity of a Newmar Essex at 54.5K pounds - Tom_BarbExplorer
ReferralMan wrote:
Tom/Barb wrote:
ReferralMan wrote:
I'm the guy that will be full-timing in a big Renegade SuperC.
At least here you'll have folks with more experience to give advice, than a bunch of Pilots
Hey Tom. Yeah, I'm sure I'll get some good advice here. You might have wanted to post this thread in the "SuperC" section of this forum.
The bus drivers here might be a little biased. ;)
Then you do it. - ReferralManExplorer
Yeah, I keep my eye on RacingJunk and have a nephew who is involved in the horse show and rodeo world. Still have to sell my house and all the contents yet before I pull the trigger. When I'm ready I'm sure the right one will eventually come along. - 1SGExplorerI understand the appeal/need for these rigs as I see a lot of them at the dragstrip.
Go for it.
Paul - ReferralManExplorer
The bus drivers here might be a little biased. ;) - Tom_BarbExplorer
At least here you'll have folks with more experience to give advice, than a bunch of Pilots - ReferralManExplorer
newman fulltimer wrote:
if you want to wrap it check with your insurance first
I'll have a commercial policy regardless. It's the CDL/FCC motor carrier rules that are foggy. Some say you're good if it's a business vehicle for personal business use and not for hire, others say you're a "commercial carrier". I'll definitely be getting a firm ruling on the matter before I hit the road.Two Jayhawks wrote:
I have looked at some that are already at limit on steer axle and have tens of thousands left over the drive's. IMO not really a great set up.
Front axles are 12K + GAWR depending on the chassis (Freightliner, Volvo, International) I end up with. I'll never come close in a million years of maxing them out. - Two_JayhawksExplorer
Edd505 wrote:
You will never be told you need a bigger truck, you over gross, you over gross, or want for more power climbing mountains or descending them. Pull a large trailer with the toys, pickup and ATV or M/C.
The comment on no storage, I camped next to one in AZ and talked with the owner as he opened all the different storage compartments getting camp setup. Looks like 5 compartments on one side, 12" out of the middle for a drive-line, and it's how wide?
If you can afford it go for it.
Not necessarily on being over weight. I have looked at some that are already at limit on steer axle and have tens of thousands left over the drive's. IMO not really a great set up. - newman_fulltimeExplorer IIif you want to wrap it check with your insurance first
- moishehExplorerIf it is a 2016 with an isx walk away. You want a dd13 ors 15
38,766 PostsLatest Activity: Jan 10, 2026
