RV94Pace's avatar
RV94Pace
Pace Arrow Diesel (1993-94) DKD Generator Belt Replacement
The Onan DKD spec D diesel generator in my RV overheats and shuts down after 20 minutes or so, and in looking I see the belt that turns the water pump & fan is extremely loose and not moving. I'm wondering how to get to it as the generator is not on a slide. It looks like the only approach is to remove the metal shrouds, then drain & remove the radiator to access the belt & belt tension adjustment (alternator on adjustable bracket like a car). If anyone has tips I would greatly appreciate suggestions!
Greg Mason
1994 Pace Arrow 36N
Cummins 8.3
1 Reply
  • since your post is 10 days or so old, and no one replied, thought I would weigh in....and you well may have fixed by now. That is tough job, changing that belt on Onan DKD. Just did one last week and took me couple hours, and I work on those things for a living.
    You have to get the fan/belt guard off to access the alternator bolts to
    loosen it. You may have to unbolt mount bolts and partially slide set out of compartment to get the guards off. Belt should be available at any auto parts store, or Onan or Kubota dealer (engine is a Kubota) Good luck!
