dons2346
May 03, 2016Explorer
bluwtr49 wrote:
I had this problem with my previous coach but they never left any reside from waxing or cleaning. What I was told is that the darker colors absorb more heat and was more susceptible to crazing due to thermal expansion/contraction. Nothing to do with the fiberglass and even the quality of the paint. Just age, sun and heat.
Unless you nose was right up to the coach they are virtually undetectable.
There was some bad stuff but you find the crazing on just about any coach and it will be in the darker colors. If you use a infrared thermometer, you can see as much as 110 degrees difference between a light color and a dark color on the same coach.
My coach was built in August 2001 and I am beginning to see the crazing in the darker trim colors, the light tan is fine.
