dockmasterdave
Nov 19, 2015Explorer
There are only two ways a paint can stick over a substrate.
1 a chemical bond, meaning it melts in to the substrate or previous finish to get a hold, or
2 a mechanical bond, meaning you sand the substrate to leave fine scratch marks for the paint to adhere to.
Yes a good primer will help over any surface.
Yes you can paint over stained wood.
They do make a paint specifically for going over a non porous surface, such as Formica. It would probably work well over the fake vinyl wood grain used in trailers, but I would take the advice of someone who has had good results.
Good luck.
Good luck.
38,782 PostsLatest Activity: Sep 10, 2026
