billskeen68 wrote:
I thought the Palazzos came with an on-demand pump that is only running when a valve is opened?
I checked mine today and I only hear it running when the faucet is turned on.
This is true of my coach as well;however, when boondocking I like to just have it activated when needed as it helps reduce the use of water as it makes the user more aware of the fact that they are using a restricted asset.
It also avoids accidental draning of the tank should a leak develop. Neither is an issue in a campground.
