chuckbear
Jul 01, 2017Explorer
Parking Brake Issue
I have been reading some on servicing the parking brake on our '99 Bounder located on the drive shaft just behind the transmission. Keep in mind that we are on the road traveling right now, heading west. I have no idea when or if the parking brake has EVER been serviced or checked. I have no idea of any problems or abuse by previous owners. The coach has 56,000 miles on it. For over a week now, I have made many attempts to remove the overflow bolt to check the fluid level, condition or even if there is fluid in the housing. I am having no luck in removing the bolt. I have tried everything except a torch to break the bolt loose and it just ain't happening.
If this were you, what would be your next step?
How much trouble could I have if the fluid is low, burn't or even gone?
Is there any symptoms that might show ahead of a failure?
Using penetrating oil and most other things are not helping. I would like some suggestions from anyone FAMILIAR with this parking brake. Chuck
