olfarmer
Mar 29, 2023Explorer II
Yes if it is a Work Horse P32 chassis, it has auto park. Check the oil in the Plastic oil tank in the steel box that is usually mounted underneath the coach on the passenger side behind the transmission. There is a place you can see the level and a black plastic cap to where you fill it. If it is out of oil fill it with automatic transmission oil. I carry a spare rotten green switch as they can cause trouble. If you want more information google "old used bear" he specializes in rebuilding auto park units and has a lot of info about them. Good Luck with your problem!
38,782 PostsLatest Activity: Aug 11, 2021
