Supercharged
Apr 29, 2013Explorer
rgatijnet1 wrote:On mine I just open up the door and drive it in plug it in.Supercharged wrote:rgatijnet1 wrote:I would just buy 4 stepping stones, should hold a 767 without any problem.Ivylog wrote:
24" deep and two layers of rebar???????? It's not a 747. OP, after sawing the 24X24 pads (you can use a cheap blade on a circular saw) only dig down 6" and go get some bags of extra strength Sackrete form HD. Even on FL sand this is thick enough and no need for rebar. At least you will not have to measure where to put these pads. Might want to mark where you tires are to make it easier to reposition the MH.
That is why you are NOT a contractor. The OP is in New Hampshire and the ground does freeze up there from time to time. Pour it the way you are recommending and it will "heave" the first time the ground freezes.
Stepping stones over a crater in the asphalt would probably break as soon as you started applying the weight.
38,741 PostsLatest Activity: Aug 02, 2025
