sundancer268
May 10, 2021Explorer
Eventually the batteries will die and your 12 volt lights, Reefer, Furnace and Water Heater will stop working. The Reefer even on 120 volts requires 12 volts for the control board. Furnace and most Water Heaters also have 12 Volt Control Boards. You need a 10-20 Amp Battery Charger with out the converter to keep going.
